It is currently Fri Jul 18, 2025 6:28 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jul 04, 2014 7:29 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
I'd dye the birdseye black and sand it back, then shoot in clear
PostPosted: Fri Jul 04, 2014 7:57 pm
First name: D
Last Name: S
Need to put in some filler and level sand. I like it.
I'll sand the body sides tomorrow. Too afraid to risk a router bit.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Jul 04, 2014 9:07 pm
State: AR
I sure like that Dan.
A cavity cover on the back matching the guard would be cool.
I've done a few like that matching the headplate and or backstrap and worked out nice.
With Wenge was probably my favorite on the ones with gold hardware.
On another site I frequent it was suggested to put small pearl dots in the screw locations on the guard...I passed.
PostPosted: Fri Jul 04, 2014 9:36 pm
Would love to see the regular maple with an orange tint for even greater contrast. Kind of like the old pumpkin color.
PostPosted: Sat Jul 05, 2014 7:13 am
State: AR
Dan I thought you may like seeing these.
It was my first attempt- I used a metal aftermarket pickguard and raised it for bearing/router blade space. (the plastic one I used was tapered on the edge and bearing had no trouble deforming it)
I was also going to use Zebra until I noticed the aftermarket pickguard didn't follow body lines as exact as I wanted. I found that out when I pencil traced using the negative on the body.
When I backed up to make a paper pattern that did follow the lower bout of body (and use to modify the positive and negative) is when I realized I could leave out the going around trem, leave enough to use the neck pocket in that area and that using Birdseye to match the fretboard would be a better choice.
I still appreciate the finish suggestions but to far along to change now.
These users thanked the author Sandywood for the post: dzsmith (Sat Jul 05, 2014 8:35 am)
